[GRASS5] [bug #3572] (grass) sql notes: INSERT INTO - mistake?
I've updated the SQL notes to reflect the new capabilities. I think more
examples are needed to reflect that properly. Can anybody produce examples of
- taking care of NULLs in a select
- 'select...where' ;
- 'alter...add column...', then 'update...set...where' ;
with complex expressions and conditions from spearfish?
With that, I'd consider this issue resolved.
Daniel.
