this bug's URL: http://intevation.de/rt/webrt?serial_num=3581
Subject: r.to.vect: assign a proper color table to the ouput
Platform: GNU/Linux/i386
grass obtained from: CVS
GRASS Version: cvs 23.08.05
r.to.vect fails to assign a colortable to the output raster which would cover the whole data range. Usually only some or none cells are visible on the raster produced by r.to.vect. This is very missleading, at first I thought there was something wrong with my data, but it showed that running r.colors fixed the problem.
Maciek
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
r.to.vect creates a vector as output, not a raster.
Moritz
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.4.1 (GNU/Linux)
Comment: Using GnuPG with Thunderbird - http://enigmail.mozdev.org
iD8DBQFDDun0rIrMbm76jD8RAh/4AJ9wWxmb72E0mgf9XfN7PSGDfDuJ5wCeMg2Z
xDtiE3nAuw1Ymi2XPbF+k4A=
=36WM
-----END PGP SIGNATURE-----
