this bug's URL: http://intevation.de/rt/webrt?serial_num=3586
Subject: r.proj error: closecell: can't move file
Platform: GNU/Linux/i386
grass obtained from: Trento Italy site
GRASS Version: 6.0.1
When using r.proj for larger files (cca 300MB+), r.proj ends with this error:
Allocating memory and reading input map... 100%
Projecting... 100%
WARNING: closecell: can't move
/home/fordfrog/data/mapy/cr-jtsk/PERMANENT/.tmp/centaur/11061.1
to null file
/home/fordfrog/data/mapy/cr-jtsk/PERMANENT/cell_misc/landsat_rgb_composite/null
/home/fordfrog/data/mapy/cr-jtsk/PERMANENT/.tmp/centaur/11061.0
to cell file
/home/fordfrog/data/mapy/cr-jtsk/PERMANENT/cell/landsat_rgb_composite
WARNING: unable to find [landsat_rgb_composite] in [PERMANENT]
WARNING: can't write range file for [landsat_rgb_composite in PERMANENT]
Each time I move the files manually (mv <source> <dest>) and they seem to be OK. The filesystem is vfat.
Miroslav ©ulc
Projecting... 100%
to null file
to cell file
Except that I can't see why this would happen only for large files I think the problem is because a Linux Grass version is run with data files on a vfat file system. We do not check file system types at run time, only platform at compile time. So something, using link() instead of CopyFile(), is breaking ?.
If so, not only r.proj is affected.
From closecell.c:
#ifdef __MINGW32__
if ( CopyFile ( FCB.null_temp_name, path, FALSE ) == 0 ) {
#else
if(link (FCB.null_temp_name, path) < 0) {
#endif
sprintf(command, "mv %s %s", FCB.null_temp_name, path);
if(system(command)) {
sprintf(buf,"closecell: can't move %s\nto null file %s",
G_warning (buf);
stat = -1;
} else {
remove ( FCB.null_temp_name );
} else {
remove ( path );
} /* null_cur_row > 0 */
> Projecting... 100%
> to null file
> to cell file
From closecell.c:
#ifdef __MINGW32__
#else
#endif
%s",
G_warning (buf);
stat = -1;
} else {
} else {
remove ( path );
This should be using rename() rather than link()+remove(). And the use
of system("mv ....") should be removed.
