Related to the v.to.rast color table problem there might
be below code in:
vector/v.to.rast/support.c
int
update_fcolors (char *raster_name)
struct Colors colors;
/* G_read_fp_range(raster_name, G_mapset(), &range); */
/* G_get_fp_range_min_max(&range, &min, &max); */
G_make_rainbow_colors(&colors, 0, 360);
G_write_colors(raster_name, G_mapset(), &colors);
return 0;
Should it be min max instead of 0 360?
be below code in:
int
return 0;
yes, I am guessing that this color table was there for v.to.rast2 for the line direction angle - min,max should cover it.
Helena
grass5 mailing list
grass5@grass.itc.it
http://grass.itc.it/mailman/listinfo/grass5
>be below code in:
>int
> return 0;
I have update v.to.rast to use min/max instead of 0..360
for floating point maps for the rainbow color table.
Also updated:
- rainbow instead of random colors for integer maps (for consistency).
- description [1]
[1] If developers update a module, please also update the description.html...
Hot candidates: the SQL related pages
> >be below code in:
> >int
> > return 0;
Also updated:
- description [1]
Oops. I think that was my all doing when I added Helena's changes to
output flow direction. I'll update the description.html immediately.
Brad Douglas <rez@touchofmadness.com>
