[GRASS5] [bug #3588] (grass) v.to.rast: assign a proper color table to the output
this bug's URL: http://intevation.de/rt/webrt?serial_num=3588
Subject: v.to.rast: assign a proper color table to the output
Platform: GNU/Linux/i386
grass obtained from: CVS
GRASS Version: cvs 23.08.05
v.to.rast fails to create a colortable covering the whole data range in the output raster. Usually only some or none cells are visible on the raster
produced by v.to.rast. This is missleading. At first I thought there was
something wrong with my data, but it showed it was all about the colortable. r.colors fixes the problem but it is not obvious for the user.
Maciek
I did something stupid and created two entries for this bug, somehow.
Only https://intevation.de/rt/webrt?serial_num=3587&display=History matters. Reply only to that.
Ticket #3588 (this one!) I killed rigt away. Ignore it.
Sorry for inconvience.
Maciek
