[GRASS5] [bug #3642] (grass) g.mremove permission denied
this bug's URL: http://intevation.de/rt/webrt?serial_num=3642
Subject: g.mremove permission denied
Platform: GNU/Linux/i386
grass obtained from: Trento Italy site
GRASS Version: 6.0.1
Doug Newcomb - debian sarge on Dual Athlon
when trying us use the gui to run Remove maps using expressions and wildcards
I get the following error( from details window):
couldn't execute "g.mremove": permission denied
    while executing
"exec -- $cmd --tcltk"
    (procedure "execute" line 4)
    invoked from within
"execute g.mremove "
    invoked from within
".#menubar.#menubar#options.#menubar#options#menu1 invoke active"
    ("uplevel" body line 1)
    invoked from within
"uplevel #0 [list $w invoke active]"
    (procedure "tk::MenuInvoke" line 47)
    invoked from within
"tk::MenuInvoke .#menubar.#menubar#options.#menubar#options#menu1 1"
    (command bound to event)
ls -al scripts/g.mremove gives:
-rwxr-xr-x 1 1338 204 3560 2005-02-11 03:46 g.mremove
Note Debian/sarge package for GRASS 6.0.1 is now available at the
DebianGIS repository, and 6.0.1 should be in Debian/unstable soon:
  http://pkg-grass.alioth.debian.org/cgi-bin/wiki.pl
wildcards I get the following error( from details window):
Don't know why you get that (user id's?), but I don't think it will
work from the GUI anyway:
[Run]
g.mremove vect=foo?
Collecting map names for current mapset <user1>...
g.remove vect=foo1,foo2,foo3
Did you mean this(y/n)?
  ^^^^ interactive prompt which won't work in the Tcl/Tk window.
needs to happen in an xterm like r.digit?
Hamish
