[GRASS5] [bug #3653] (grass) changing regions within ps.map file
this bug's URL: http://intevation.de/rt/webrt?serial_num=3653
Subject: changing regions within ps.map file
Platform: GNU/Linux/i386
grass obtained from: CVS
Hello,
Would it be very difficult to implement the possibility to change regions in a single ps.map instruction file ? This would allow creating layouts with several maps, such as one of a large region and one of a zoom in one single run. Right now I have to create two ps.map instruction files, run them separately and change region in between, and then put them together in a drawing program.
Maybe a "simple"(?) ps.map element allowing to launch a system command could be a solution ? But this obviously depends on how binding the order of commands in ps.map is. Otherwise, adding a "region" element to the individual map commands, such as:
vareas MyMap1
  region XXX
end
vareas MyMap
  region YYY
end
Moritz
Hello,
drawing program.
vareas MyMap1
  region XXX
end
vareas MyMap
  region YYY
end
Just realised that ps.map actually doesn't allow placing several seperate maps
in one run, or have I missed something ? So this would obviously be a
precondition. Something in the lines of d.frames, but in ps.map...
Moritz
seperate maps in one run, or have I missed something ? So this would
obviously be a precondition. Something in the lines of d.frames, but
in ps.map...
ps.map is locked into one region for the session, but you can draw a box
around a subregion within the map by using the "region" instruction. (just
fixed in CVS a few days ago and could use some testing!)
Hamish
