[GRASS5] [bug #3673] (grass) location setup: sterea yields
this bug's URL: http://intevation.de/rt/webrt?serial_num=3673
Subject: location setup: sterea yields
Platform: GNU/Linux/i386
grass obtained from: CVS
GRASS Version: cvs 07.09.2005
Although Grass supports sterea projection via PROJ.4 library, sterea is recognized as an "invalid projection" at the location setup stage in Grass 6.1 cvs.
Maciek
That would be because it isn't in the list in lib/gis/projections.
Has it been recently added to PROJ (i.e. the last 5 years :wink: ) That might explain why it's not there. But adding support for it to g.setproj would probably involve changes to lib/gis/geo_init.c and maybe other files as well.
If you know the parameters there is no problem to manually set it up by editing the PROJ_INFO or even put it in with g.proj using EPSG codes or WKT files etc. All the g.setproj and G_geo_* stuff is just a bit of a hack to make up for the absence in PROJ of a specification of the parameters associated with each projection. It doesn't attempt to be definitive for all the projections supported and never will.
I asked the author of PROJ about this once but on a point of principle he doesn't want to produce such a definitive specification and prefers that
people read the PROJ documentation and understand the parameters they are
using, rather than answer a series of questions like g.setproj attempts to do.
Paul
