d.m still prints some output to the terminal - when opening new monitors:
press eg. "x1":
GRASS 6.1.cvs (caves_xy):~ > using default visual which is TrueColor
ncolors: 16777216
Graphics driver [x1] started
Could that be redirected to the d.m log window too?
Maciek
press eg. "x1":
ncolors: 16777216
That case is problematic. The reason is that it's the monitor driver
which displays the text. If you allow the output from "d.mon start="
to be returned to Tcl, the command won't finish until the driver
terminates.
Apart from anything else, this means that you can't quit d.m and leave
the monitor open.
The only practical solution is to redirect the output somewhere,
either to the terminal on which d.m is running, to a file, or to
/dev/null.
