[GRASS5] [bug #3710] (grass) d.m - store commands in the history
Glynn wrote:
Are you referring to ~/.bash_history (and similar)? Those files belong
to the shell; d.m shouldn't be messing with them.
I guess that he refers to $MAPSET/.bash_history where d.m IMHO could
add commands without too many problems.
Yes, that's what I refer to. Sorry I couldn't reply earlier.
It is a shame the user can't get back to commands which were issued from GUI. Any chances?
Maciek
W polskim Internecie sÂą setki milionĂłw stron. My przekazujemy Tobie tylko najlepsze z nich!
http://katalog.epf.pl/
It isn't quite that simple.
1. Changes to the history file won't effect existing processes unless
you force them to re-read the history file with "history -r".
2. bash doesn't simply append commands to the history file as they are
entered. It writes out the history in one go upon termination (or when
forced with "history -w"). So, commands appended to the file by
another process won't appear in the "right" place in the history.
3. Multiple shells can use the same history file; different shells
will read commands from different offsets in the file. E.g. if you
have three shells running, quit them, start 3 new shells, each new
shell will start where one of the others left off in terms of their
history.
4. d.m doesn't use a shell; it uses Tcl's "exec" command. A shell
command is a string, while a Tcl's exec command takes a list of
strings. Tcl would have to generate an equivalent shell command
according to the syntax rules for the shell (which might not be bash).
Although the d.m layers don't write to the command history upon display,
they CAN be saved as a "group". This group can then be opened in the future,
reinitializing all the saved GIS Manager layers.
To get the commands to save to the command history, you'd need to write a
shell script with the same commands. This is pretty easy because, when you
push the display button, all the commands get written to the terminal. From
there, you can cut and paste them into a shell script--or just to the
terminal one by one to populate the command history.
As with many things in GRASS, if you can't do it one way, there are a couple
other alternative methods to achieve the same or similar results.
Hope this is helpful.
Michael
Arizona State University
Tempe, AZ 85287-2402
phone: 480-965-6213
fax: 480-965-7671
Date: Sat, 8 Oct 2005 10:59:24 +0100
To: Markus Neteler via RT <grass-bugs@intevation.de>
Cc: <werchowyna@epf.pl>, <grass5@grass.itc.it>
Subject: Re: [GRASS5] [bug #3710] (grass) d.m - store commands in the history
history.
