this bug's URL: http://intevation.de/rt/webrt?serial_num=3740
Subject: g.setproj Segmentation fault when trying to create custom geodetic datum
Platform: GNU/Linux/i386
grass obtained from: Mirror of Trento site
grass binary for platform: Downloaded precompiled Binaries
GRASS Version: 6.0.1
I'm trying to generate a new projection for an already existing location.
There is NO projection information at the moment in the location, so the name of the location is (null).
When using g.setproj, I choose to create custom geodetic datum and just after entering the false northing, a Segmentation fault arises.
The bug appears always and has been tested with the Gentoo 2005 and SUSE 9.3 distributions.
The workaround is to generate any NOT CUSTOM projection information and then to manually edit the PROJ_INFO file.
Can you give some more information on what prompts you are getting and your responses. It may be nothing to do with a custom datum if the problem is at the false northing stage... that is when details of the projection are being entered. Perhaps you are using a projection that has buggy support from g.setproj. It doesn't support interactive entering of all projections in PROJ and is known to have bugs in some that it does support (lcc comes to mind). If you know the PROJ parameters you can manually edit the PROJ_INFO file after setting up to fix it and things will work just as well.
Paul
