this bug's URL: http://intevation.de/rt/webrt?serial_num=3741
Subject: r.cost WARNING: segment_pagein: No such file or directory
Platform: GNU/Linux/i386
grass obtained from: CVS
GRASS Version: CVS
the following problem appears when using r.cost:
r.cost in=allarea.one out=distance2water start_rast=streams percent_memory=100
Peak cost value: 64.485281
Interestingly, the result map is generated.
But the message is confusing.
Thanks
Daniela
