this bug's URL: http://intevation.de/rt/webrt?serial_num=3749
Subject: v.patch: 3d vector + 3d vector = 2d vector
If you run v.patch with multiple 3D vector files, the output is always 2D and
the z-data is lost.
Hamish
is anyone working on it? May I try to fix it? I am bored;-)
Best,
Martin
2005/10/17, Request Tracker <grass-bugs@intevation.de>:
the z-data is lost.
Hamish
grass5 mailing list
grass5@grass.itc.it
http://grass.itc.it/mailman/listinfo/grass5
THANKS VERY MUCH for the offer, Martin. If you do, could you look into
adding an option to merge attributes too? At least for vector files that
have identical attribute structures, it should be possible to append the
attributes of the files like the spatial objects. I did a little script hack
that does this via OGR (v.append), but doing it correctly in the v.patch
module would be much better.
Michael
______________________________
Arizona State University
Tempe, AZ 85287-2402
USA
voice: 480-965-6262; fax: 480-965-7671
Date: Mon, 17 Oct 2005 15:30:16 +0200
To: grassdev <grass5@grass.itc.it>
Subject: Re: [GRASS5] [bug #3749] (grass) v.patch: 3d vector + 3d vector = 2d
vector
Best,
Martin
the z-data is lost.
Hamish
grass5 mailing list
grass5@grass.itc.it
