this bug's URL: http://intevation.de/rt/webrt?serial_num=3779
Subject: d.m: window height control between layers list and layer properties needed
Platform: GNU/Linux/i386
grass obtained from: CVS
GRASS Version: cvs 26.10.2005
I miss the ability to control the height of layers list window and layer properties window in d.m. I find uncomfortable to control their height by dragging the d.m commands window, which is the only way for now.
Otherwords, see:
http://www.biol.uni.wroc.pl/sieczka/udostepnione/grass/dm/d.m_enh_req.png
It would be great if the control from point no 1. could be added to point no 2. as well.
Maciek
If anyone knows how to implement a set of vertically-oriented paned windows
(monitor buttons and layer tree), followed by a pair of
horizontally-oriented paned windows (options panel and output window) with a
movable sash between them please implement it--or tell me and I will
implement it.
As far as I can see, you have to create paned windows as either vertical or
horizontal. That means that you have to create two different paned windows
if you want to switch from vertical to horizontal.
Michael
Arizona State University
Tempe, AZ 85287-2402
phone: 480-965-6213
fax: 480-965-7671
Reply-To: Request Tracker <grass-bugs@intevation.de>
Date: Fri, 28 Oct 2005 16:11:59 +0200 (CEST)
To: <grass5@grass.itc.it>
Subject: [GRASS5] [bug #3779] (grass) d.m: window height control between
needed
Otherwords, see:
2. as well.
Maciek
