[GRASS5] [bug #3800] (grass) script tests fail on some platforms
this bug's URL: http://intevation.de/rt/webrt?serial_num=3800
Subject: script tests fail on some platforms
see http://grass.itc.it/pipermail/grass5/2005-November/020021.html
this seems to fail on some platforms:
E00CONV="`which e00conv`"
if [ "$EOOCONV" == "" ] ; then
  echo error
  exit
fi
works:
  if [ -z "$E00CONV" ] ; then
probably also
  if [ "$VAR" != "" ] ; then
should be
  if [ -n "$VAR" ] ; then
affected modules:
$ grep -rI '""' scripts/* | cut -f1 -d/ | sort | uniq
d.correlate
d.monsize
d.out.file
d.rast.leg
d.resize
d.slide.show
d.split
d.vect.thematic
db.test
g.mlist
g.mremove
i.fusion.brovey
i.image.mosaic
i.in.spotvgt
i.oif
i.spectral
i.tasscap
r.fillnulls
r.in.aster
r.in.srtm
r.mapcalculator
r.plane
r.reclass.area
r.regression.line
r.shaded.relief
r.univar.sh
r3.mapcalculator
v.build.all
v.convert.all
v.db.addcol
v.db.addtable
v.db.droptable
v.db.reconnect.all
v.db.update
v.in.gns
v.in.mapgen
v.in.sites.all
v.rast.stats
v.univar.sh
Hamish
"==" isn't valid expression syntax; it's just "=".
sorry that was my mistake, the test that fails is in fact
> E00CONV=`which e00conv`
> if [ "$EOOCONV" = "" ] ; then
http://freegis.org/cgi-bin/viewcvs.cgi/grass6/scripts/v.in.e00/v.in.e00.diff?r1=1.11&r2=1.12
Maybe the error is
without quotes around "``" if there is spaces in the path? :confused: I don't
think so, but..
I don't know if this was on Mac or Cygwin & can't test.
Hamish
