this bug's URL: http://intevation.de/rt/webrt?serial_num=3808
Subject: d.rast segmentation fault on GRASS6.1.cvs
Platform: GNU/Linux/i386
grass obtained from: Trento Italy site
grass binary for platform: Downloaded precompiled Binaries
GRASS Version: 6.1.cvs-i686-pc-linux-gnu-05_11_2005
Clicking "display active layers" from the GUI produces a blank monitor (it brings one up when none exists), showing message "d.rast map-dem_ns -o 0%" in the "command" section of the GUI. Calling d.rast from terminal (having called "d.mon start-x0" first to bring up monitor) produces segmentation fault message (still blank monitor). Calling "display active layers" from GUI with legend (i.e. d.legend) produces blank x0 but proper legend in x1 for the subject raster file. Same raster files plot perfectly in GRASS 6.0.1. Calling d.vect produces perfect results in GRASS 6.1.cvs (hey, thanks for adjustable pixel width for vectors - it's great!).
Running linux Fedora Core2 (no upgrades to kernel)
proj-4.4.9-1
gdal-1.2.1-1suse93
gdal-grass-1.3.0-2mdk10.1
geos-2.1.4-1suse93
(installed in that order, used rpm files from different distributions to satisfy dependencies when installing ... it's easier that way than compiling).
Rick
