Subject: Print display manager (to file) does not print graphics (scale, grid)
Platform: GNU/Linux/i386
grass obtained from: Trento Italy site
grass binary for platform: Downloaded precompiled Binaries
GRASS Version: both 6.0.1 and 6.1.cvs
Clicking "print raster and vector maps using ps.map" with scale and/or grid on display and printing to file or paper does not produce scale or grid in printed product. This would be nice to have, as creating a snapshot of monitor using "save display to image file" in either .png or .xwd format does not produce satisfactory resolution for many report-printing jobs.
Also, "save diaplay to image file" using .png format produces vector components that are too small (i.e. thin lines, symbols and text too small).
Otherwise, very nice work on GRASS. Many thanks.
Rick
for d.out.png, change the resolution. A resolution of 1 gives an exact match
of what you see on the screen. A resolution of 2 gives 2x2 for each screen
pixel. This makes the rasters look nicer, but the vectors and text smaller.
Even more so for a resolution of 4 (4x4 for each pixel).
I changed the default png resolution to 1x1 when I upgraded d.out.png to
d.out.file.
Michael
______________________________
Arizona State University
Tempe, AZ 85287-2402
USA
Rick
(scale, grid)
Use the ps.map "mapinfo" instruction for scale and bounds information
and the "scalebar" instruction to draw a scalebar. The "grid" and
"geogrid" instructions take care of the grids. It is hoped that the
print with ps.map button produces a command file template that gets
you close; you can then copy and tweak as needed.
small).
maybe have d.out.png find and change any d.vect calls to use width=$res
? maybe not
