[GRASS5] [bug #3826] (grass) two r.resamp.rst issues
this bug's URL: http://intevation.de/rt/webrt?serial_num=3826
Subject: two r.resamp.rst issues
If you run r.resamp.rst at a resolution other that that of the input map, the
output elev map is not created at the specified ew_res= and ns_res= resolution.
A warning is given that you are doing so, but it doesn't mention why that
might be bad. Interestingly the output map is actually written at the target
resolution, but it contains the data resolution from the original map. (target
was 50m, original was 100m)
If the input map is in another mapset (map@othermapset) then it gives an error
that the input map can't be found. (happens when it tries to copy the color
table I think) and exits with an error. (but processing is already done so
output map is ok, just without a colortable)
Hamish
ps - I've tidied up the module's code and strings a bit in CVS, so cvs update
before fixing...
Hamish,
We've run into that here too. One of my RA's did a test of interpolating to
a higher resolution using r.resamp.rst and the more complicated procedure of
generating a large number of points from a raster map, and then
interpolating from the points to a higher resolution.
r.resamp.rst is faster and more straightforward. BUT (a VERY big but), it
behaves exactly as you describe. It simply turns out a map that looks just
like the original map is subdivided into more grid cells, without any
interpolation. This makes the module essentially useless.
Michael
Arizona State University
Tempe, AZ 85287-2402
phone: 480-965-6213
fax: 480-965-7671
Reply-To: Request Tracker <grass-bugs@intevation.de>
Date: Sat, 12 Nov 2005 13:37:05 +0100 (CET)
To: <grass5@grass.itc.it>
Subject: [GRASS5] [bug #3826] (grass) two r.resamp.rst issues
resolution.
Hamish
before fixing...
Michael Barton wrote:
Hamish,
It's not useless because if you run the module at a resolution equal to the input raster map, the result is OK.
The warning message should be replaced by a fatal error that exits the command.
Jaro
Michael
phone: 480-965-6213
fax: 480-965-7671
resolution.
Hamish
before fixing...
grass5 mailing list
grass5@grass.itc.it
http://grass.itc.it/mailman/listinfo/grass5
Perhaps we misunderstand each other, or maybe it works for you.
The whole point of the module is to change the resolution of the raster map.
In my recent experience (I've tried it on a Mac and on Fedora Core 4), this
doesn't seem to work, regardless of the region settings when you run the
module. It changes the resolution, but it seems to have the effect of simply
making more grid cells without correctly interpolating between them. For
example, going from a 30m resolution DEM to a 15m resolution using
r.resamp.rst seems to produce 4 15m cells within the area of an original 30m
cell, but each of the 15m cells has the same resolution as the original
cell. This is not how it should work.
Michael
phone: 480-965-6213
fax: 480-965-7671
Date: Sun, 13 Nov 2005 23:20:06 +0100
To: Michael Barton <michael.barton@asu.edu>
Cc: <grass5@grass.itc.it>, Helena Mitasova <hmitaso@unity.ncsu.edu>
Subject: Re: [GRASS5] [bug #3826] (grass) two r.resamp.rst issues
Hamish,
command.
Jaro
Michael
phone: 480-965-6213
fax: 480-965-7671
the
resolution.
(target
error
Hamish
update
before fixing...
grass5 mailing list
grass5@grass.itc.it
raster map. In my recent experience (I've tried it on a Mac and on
Fedora Core 4), this doesn't seem to work, regardless of the region
settings when you run the module. It changes the resolution, but it
seems to have the effect of simply making more grid cells without
correctly interpolating between them. For example, going from a 30m
resolution DEM to a 15m resolution using r.resamp.rst seems to produce
4 15m cells within the area of an original 30m cell, but each of the
15m cells has the same resolution as the original cell. This is not
how it should work.
The current region resolution needs to match the input map's resolution,
then it should work. Could you try the latest cvs version and see if you
can replicate the error?
Hamish
