this bug's URL: http://intevation.de/rt/webrt?serial_num=3853
Subject: db.connect not working when invoked with '-p'
Platform: GNU/Linux/i386
grass obtained from: CVS
GRASS Version: CVS 2005-11-16
When using a -p switch in db.connect the database connection doesn't change.
I'm currently connected to sqlite and want to switch to dbf and see if it worked, thus I do:
db.connect driver=dbf database='$GISDBASE/$LOCATION_NAME/$MAPSET/dbf/' -p
But the driver is still sqlite:
driver:sqlite
database:$GISDBASE/$LOCATION_NAME/$MAPSET/sqlite.db
schema:(null)
group:(null)
I thought it would work like "g.region -p" - apply required changes and print the result.
Maciek
