this bug's URL: http://intevation.de/rt/webrt?serial_num=3869
Subject: g.remove fails on vector map if raster reclass map present
grass obtained from: CVS
hi,
an "amusing" bug:
g.remove vect=roads_roads_roads_roads_roads_roads_roads
[roads_roads_roads_roads_roads_roads_roads@sqlite] is a base map. Remove reclassed maps first:
interstate@user1,roads.rcl@user1
IMHO g.remove vect=... should not no bother about raster (reclass) maps
with identical name.
g.list vect
Vorhandene vector Dateien im Mapset sqlite:
myfields roads_roads_roads_roads_roads_roads_roads spearfish_soils
mypoints3D roads_roads_roads_roads_roads_roads_roads_buf test
g.list rast
Vorhandene raster Dateien im Mapset sqlite:
myfields_v_rast_stats.21322 roads_roads_roads_roads_roads_roads_roads
[the stupid name was selected to tract a gui.tcl bug, instead I discovered
this one].
