On Thu, Feb 09, 2006 at 11:30:42AM +0000, Paul Kelly wrote:
On Mon, 6 Feb 2006, Maciek Sieczka via RT wrote:
>Creating new location from an EPSG code fails. Maybe due to Paul's recent
>changes? This problem could be populate to 6.02 candidate as well then.
>I tried to create a location from EPSG code 2180. There was no error,
>location
>was created. My path to /usr/local/share/proj/epsg is ok. However the
>location
>is not projected:
The EPSG codes are read from $(GISBASE)/etc/ogr_csv/pcs.csv and not
/usr/local/share/proj/epsg, if that makes any difference.
Something to try to be sure is g.proj -p proj4=+init=epsg:2180 and it
should print the correct co-ordinate system in GRASS format.
The conversion logic is mostly in OGR. The PROJ.4 string is never
interpreted by PROJ in this case but by OGR.
This
works again (tested in Spearfish).
v.in.ogr still fails (here it should display the contents of the .prj
file, not 0):
GRASS 6.1.cvs (spearfish60):~/data/vmap0 > v.in.ogr polbnda_italy_GB_ovest.shp out=test
ERROR: Projection of dataset does not appear to match current location.
LOCATION PROJ_INFO is:
datum: nad27
nadgrids: conus
proj: utm
ellps: clark66
a: 6378206.4000000004
es: 0.0067686580
f: 294.9786982000
zone: 13
cellhd.proj = 0 (unreferenced/unknown)
You can use the -o flag to v.in.ogr to override this check.
Consider to generate a new location with 'location' parameter from
input data set.
GRASS 6.1.cvs (spearfish60):~/data/vmap0 > cat polbnda_italy_GB_ovest.prj
PROJCS["Transverse Mercator",GEOGCS["international",DATUM["D_Monte_Mario",SPHEROID["international",6378388,297]],PRIMEM["Greenwich",0],UNIT["Degree",0.017453292519943295]],PROJECTION["Transverse_Mercator"],PARAMETER["latitude_of_origin",0],PARAMETER["central_meridian",9],PARAMETER["scale_factor",0.9996],PARAMETER["false_easting",1500000],PARAMETER["false_northing",0],UNIT["Meter",1]]
Maybe it has to do with the definition of
OGRSpatialReferenceH
