[GRASS5] [bug #3889] (grass) r.in.arc: fails on r.out.gdal output
this bug's URL: http://intevation.de/rt/webrt?serial_num=3889
Subject: r.in.arc: fails on r.out.gdal output
Platform: GNU/Linux/i386
grass obtained from: CVS
GRASS Version: 6.1 2005-11-16
r.in.arc is not able to handle ArcInfo ASCII grids produced by r.out.gdal. They have 'NODATA_value nan' about which r.in.arc says:
r.in.arc input=dem_5.arc output=dem_5.arc_arc type=FCELL mult=1.0
r.in.arc: ** errors detected in header section **
  illegal "nodata_value" value in header
    nodata_value: na
However, the import proceeds, yet the resulting raster is strange:
GRASS 6.1.cvs (poloniny_65):~ > r.info -r dem_5.arc_arc
min=nan
max=nan
This means it is impossible to assign it a colortable and on d.rast nothing is displayed. Yet d.what.rast says there are cells with valid, expected values.
Either r.out.gdal should be prevented from using 'nan' for 'no data' when exporting to AAIGrid, or r.in.arc should be fixed to handle such grids.
Which approach would be correct?
Maciek
