But GRASS won't create a new theme (there is result theme "buff_ausschnitt", but it is not possible to open it: QGIS "The layer is no valid layer and cannot be added to the map").
After that, I tried to first create a line buffer theme (works fine) and then convert it to a area boundary theme using v.type. However, the new area boundary theme does not have the shape of the line buffer theme. The new created polygon fills out the space inside the ring.
Wolfgang
If there are no boundary features in the input map, the buffering around
boundaries will be empty. Use v.type to convert.
Remember that lines will be buffered both sides, areas (boundaries) only
outside themseleves.
