this bug's URL: http://intevation.de/rt/webrt?serial_num=3966
Subject: Refernce to -z option in r.slope.aspect is obsolete
Platform: GNU/Linux/i386
grass obtained from: CVS
GRASS Version: GRASS 6.1.cvs checked out 20060107
Documentation for r.slope.aspect makes reference to a -z option for rasters that contain valid elevations with VALUE = 0. This appears to be no longer an option (hopefully no longer required)?
Example:
r.slope.aspect -z elev=dem_60ft aspect=test
Sorry, <z> is not a valid flag
Description:
Generates raster map layers of slope, aspect, curvatures and partial derivatives from a raster map layer of true elevation values. Aspect is calculated counterclockwise from east.
Usage:
r.slope.aspect [-aq] elevation=string [slope=string] [format=string]
[prec=string] [aspect=string] [pcurv=string] [tcurv=string]
[dx=string] [dy=string] [dxx=string] [dyy=string] [dxy=string]
[zfactor=value] [min_slp_allowed=value]
Flags:
-a Do not align the current region to the elevation layer
-q Quiet
<snip>
David Finlayson
david.p.finlayson@gmail.com
