this bug's URL: http://intevation.de/rt/webrt?serial_num=3967
Subject: Undocumented: max() returns integer values if at least one argument is an int
Platform: GNU/Linux/i386
grass obtained from: CVS
GRASS Version: GRASS 6.1.cvs checked out 20050106
According to the r.mapcalc documentation page, max() returns a float if any of its arguments are floats. In fact, map() returns an integer result if any of its arguments are integers!
example:
r.mapcalc "temp1 = 0" # CELL
r.mapcalc "temp2 = 0.1" # FCELL
r.mapcalc "temp3 = max(temp1, temp2)" # Returns 0!
r.mapcalc "temp4 = max(float(temp1), temp2)" # Returns 0.1!
This is confusing. I suppose this is a C library thing. In the scripting languages I use, the cast to float is implicit in these situations.
Minor fix: update the docs to make clear the behavior
Major fix: implicit promotion to float if either (any) raster is of type float or double
David
