[GRASS5] [bug #3973] (grass) ./configure: FORTRAN compiler not set
this bug's URL: http://intevation.de/rt/webrt?serial_num=3973
Subject: ./configure: FORTRAN compiler not set
Platform: GNU/Linux/i386
grass obtained from: CVS
GRASS Version: cvs 2005.01.10
Although I have g77 and f77 present in my system...
$ f77 --version
GNU Fortran (GCC) 3.4.5 20050809 (prerelease) (Ubuntu 3.4.4-6ubuntu8)
Copyright (C) 2004 Free Software Foundation, Inc.
$ g77 --version
...the FORTRAN compiler is not set at ./configure:
GRASS is now configured for: i686-pc-linux-gnu
Source directory: /home/john/src/straight/grass6
Build directory: /home/john/src/straight/grass6
Installation directory: /usr/local/grass-6.1.cvs
Startup script in directory: ${exec_prefix}/bin
C compiler: gcc -g -O2
C++ compiler: c++ -g -O2
FORTRAN compiler: <- SHOULDN'T IT BE g77 OR STH?
Building shared libraries: yes
64bit support: no
  NVIZ: yes
  X11 support: yes
  JPEG support: yes
  TIFF support: yes
  PNG support: yes
  Tcl/Tk support: yes
  PostgreSQL support: yes
  MySQL support: no
  SQLite support: yes
  FFMPEG support: no
  OpenGL(R) support: yes
  ODBC support: no
  FFTW support: yes
  BLAS support: no
  LAPACK support: no
  Motif support: no
  FreeType support: yes
  GLw support: no
  NLS support: no
  Readline support: no
  C++ support: yes
  openDWG support: no
  GDAL support: yes
  OGR support: yes
  Large File Support (LFS): yes
Maciek
The check was disabled in configure.in:
  revision 1.65
  date: 2004/11/29 09:17:58; author: markus; state: Exp; lines: +1 -1
  disabled F77 as not needed
lib/cdhc still has some Fortran files, but they aren't used.
  revision 1.65
See
http://intevation.de/rt/webrt?serial_num=2731
You suggested to (probably) remove it:
  Glynn Clements glynn at gclements.plus.com
  Sun, 28 Nov 2004 05:18:33 +0000
  "The configure check should probably be removed."
  http://grass.itc.it/pipermail/grass5/2004-November/016200.html
So, do we want it back? Doesn't it confuse people who do not have
Fortran installed (such as the ongoing BLAS/LAPACK confusion)?
> revision 1.65
See
At a minimum, while the f77/g77 check in configure.in is disabled, the
"FORTRAN compiler" message should also be disabled.
Also, if the Fortran files in lib/cdhc are no longer necessary, they
> > revision 1.65
> See
Someone may to submit necessary changes.
