[GRASS5] [bug #3974] (grass) r.mapcalc/libgis failure with LFS enabled
As (indirectly) suggested, I have added
#include "config.h"
to:
./raster3d/r3.in.v5d/v5d.c
./raster3d/r3.out.v5d/v5d.c
./raster/r.thin/io.c
./lib/gis/opencell.c
./lib/image/rdwr.c
./lib/segment/seek.c
as 'off_t' is used in these files.
The problem seems to persist, though.
#include "config.h"
to:
./lib/image/rdwr.c
I note that gis.h includes config.h, but it does so after it includes
stdio.h. That may have an impact.
Also, it's possible that some code is assuming that an off_t is the
same size as a long.
I'd suggest that it's likely to be simpler to change the way that
large file support is implemented so that it only applies to source
files which specifically allow for it.
I.e. rather than setting _FILE_OFFSET_BITS in config.h, define a
separate macro (e.g. GRASS_LARGEFILE) and modify specific source files
to do:
  #ifdef GRASS_LARGEFILE
  #define _FILE_OFFSET_BITS 64
  #endif
before including any headers.
The most obvious candidates are the files containing the core raster
I/O code (opencell.c, get_row.c, put_row.c, format.c).
> #include "config.h"
> to:
> ./lib/image/rdwr.c
to do:
  #endif
I will leave these fixes to the original author(s) of LFS
support in GRASS since I don't know enough about these details.
Could the new bug categories "doc-grass6" and "dos-wisg-grass6" be made
available for bug reports on grass.itc.it/bugtracking/bugreport.html ?
Maciek
Szukasz do¶wiadczonej firmy poligraficznej? Zale¿y Ci na terminowo¶ci i atrakcyjnych cenach?
Zapraszamy do nas!
http://www.foldruk.pl/
On Thu, Jan 12, 2006 at 09:11:21PM +0100, Maciek Sieczka wrote:
Maciek
Done.
