The same dead link is in r.topidx.
Maciek
Maciek
Using Ubuntu 5.10 Breezy, gcc 3.4.4. Plenty of other stuff, all either
CVS or newest releases, built fine today (hdf4, proj, geos, postgis,
sqlite, gdal).
My ./configure:
--with-cxx
--without-odbc
--with-sqlite
--with-tcltk-includes="/usr/include/tcl8.3/"
--with-postgres-includes="/usr/include/postgresql/"
--with-freetype
--with-freetype-includes="/usr/include/freetype2/"
--with-readline
$ cat error.log
GRASS GIS compilation log
Started compilation: nie sty 29 22:26:50 CET 2006
Errors in:
/home/fishoo/src/straight/grass6/lib/gis
/home/fishoo/src/straight/grass6/lib/gmath
/home/fishoo/src/straight/grass6/lib/raster
/home/fishoo/src/straight/grass6/lib/display
/home/fishoo/src/straight/grass6/lib/D
/home/fishoo/src/straight/grass6/lib/db/dbmi_base
/home/fishoo/src/straight/grass6/lib/db/dbmi_client
/home/fishoo/src/straight/grass6/lib/db/stubs
/home/fishoo/src/straight/grass6/lib/db/dbmi_driver
/home/fishoo/src/straight/grass6/lib/edit
/home/fishoo/src/straight/grass6/lib/form
/home/fishoo/src/straight/grass6/lib/imagery
/home/fishoo/src/straight/grass6/lib/proj
/home/fishoo/src/straight/grass6/lib/segment
/home/fishoo/src/straight/grass6/lib/vector/diglib
/home/fishoo/src/straight/grass6/lib/vector/Vlib
/home/fishoo/src/straight/grass6/lib/sites
/home/fishoo/src/straight/grass6/lib/rst/interp_float
<snip>
# 300 more here
</snip>
Finished compilation: nie sty 29 22:33:04 CET 2006
(In case of errors please change into the directory with error and run
'make')
3 error examples:
$ cd /home/fishoo/src/straight/grass6/lib/gis ; make make: *** No rule
to make target `OBJ.i686-pc-linux-gnu/sample.o', needed by
`/home/fishoo/src/straight/grass6/dist.i686-pc-linux-gnu/lib/libgrass_gis.6.1.cvs.so'.
Stop.
$ cd /home/fishoo/src/straight/grass6/lib/gmath ; make
gcc -shared
-o /home/fishoo/src/straight/grass6/dist.i686-pc-linux-gnu/lib/libgrass_gmath.6.1.cvs.so
-Wl,--export-dynamic
-L/home/fishoo/src/straight/grass6/dist.i686-pc-linux-gnu/lib
-Wl,-rpath-link,/home/fishoo/src/straight/grass6/dist.i686-pc-linux-gnu/lib
OBJ.i686-pc-linux-gnu/brent.o OBJ.i686-pc-linux-gnu/dalloc.o
OBJ.i686-pc-linux-gnu/del2g.o OBJ.i686-pc-linux-gnu/eigen.o
OBJ.i686-pc-linux-gnu/eigen_tools.o OBJ.i686-pc-linux-gnu/fft.o
OBJ.i686-pc-linux-gnu/gauss.o OBJ.i686-pc-linux-gnu/getg.o
OBJ.i686-pc-linux-gnu/ialloc.o OBJ.i686-pc-linux-gnu/jacobi.o
OBJ.i686-pc-linux-gnu/la.o OBJ.i686-pc-linux-gnu/lu.o
OBJ.i686-pc-linux-gnu/max_pow2.o OBJ.i686-pc-linux-gnu/mult.o
OBJ.i686-pc-linux-gnu/rand1.o OBJ.i686-pc-linux-gnu/svd.o -lgrass_gis
-lgrass_datetime -lz -lfftw -lm && if [ -z "" ] ; then ln -f -s
libgrass_gmath.6.1.cvs.so /home/fishoo/src/straight/grass6/dist.i686-pc-linux-gnu/lib/libgrass_gmath.so;
fi /usr/bin/ld: cannot find -lgrass_gis collect2: ld returned 1 exit
status make: ***
[/home/fishoo/src/straight/grass6/dist.i686-pc-linux-gnu/lib/libgrass_gmath.6.1.cvs.so]
Error 1
$ cd /home/fishoo/src/straight/grass6/raster/r.los ; make gcc
-DPACKAGE=\""grassmods"\"
-o /home/fishoo/src/straight/grass6/dist.i686-pc-linux-gnu/bin/r.los
OBJ.i686-pc-linux-gnu/color_rnge.o OBJ.i686-pc-linux-gnu/delete.o
OBJ.i686-pc-linux-gnu/main.o OBJ.i686-pc-linux-gnu/make_list.o
OBJ.i686-pc-linux-gnu/make_point.o OBJ.i686-pc-linux-gnu/mark_pts.o
OBJ.i686-pc-linux-gnu/pts_elim.o OBJ.i686-pc-linux-gnu/segment.o
-lgrass_segment -lgrass_gis -lgrass_datetime -lz -lm
-lz /usr/bin/ld: cannot find -lgrass_segment collect2: ld returned 1
exit status make: ***
[/home/fishoo/src/straight/grass6/dist.i686-pc-linux-gnu/bin/r.los]
Error 1
I wanted to attach the make.log, but it's over 60 KB bzipped and the
message gets rejected. Only config.log attached, if this helps somehow.
Maciek
Szukasz do?wiadczonej firmy poligraficznej? Zale?y Ci na terminowo?ci i atrakcyjnych cenach?
Zapraszamy do nas!
http://www.foldruk.pl/
config.log.bz2 (4.42 KB)
Maciek,
there was a change in libgis, probably the CVS snapshot was
generated while things were still in modification.
I have now removed four unused files from lib/gis/ and
simplified lib/gis/Makefile (registration of object files
is no longer needed there).
I'll relaunch the cronjob to generate the CVS snapshot
now.
sqlite, gdal).My ./configure:
--with-cxx
--without-odbc
--with-sqlite
--with-freetype
--with-readline$ cat error.log
Errors in:
/home/fishoo/src/straight/grass6/lib/rst/interp_float<snip>
# 300 more here
</snip>--
'make')3 error examples:
Stop.$ cd /home/fishoo/src/straight/grass6/lib/gmath ; make
gcc -shared
status make: ***
Error 1$ cd /home/fishoo/src/straight/grass6/raster/r.los ; make gcc
Error 1I wanted to attach the make.log, but it's over 60 KB bzipped and the
message gets rejected. Only config.log attached, if this helps somehow.Maciek
Zapraszamy do nas!
Markus Neteler <neteler itc it> http://mpa.itc.it
ITC-irst - Centro per la Ricerca Scientifica e Tecnologica
MPBA - Predictive Models for Biol. & Environ. Data Analysis
Via Sommarive, 18 - 38050 Povo (Trento), Italy
On Mon, 30 Jan 2006 09:12:06 +0100
Markus Neteler <neteler@itc.it> wrote:
Maciek,
generated while things were still in modification.I have now removed four unused files from lib/gis/ and
is no longer needed there).I'll relaunch the cronjob to generate the CVS snapshot
now.
Markus,
I'm not using the CVS snapshot - I fetch directly from CVS. Last time I
updated yesterday ~ 10 pm, and it failed to build.
I'll update again today afternoon and see if now Grass61 builds.
Thanks.
Maciek
Zapraszamy do nas!
On Mon, 30 Jan 2006 09:42:53 +0100
Maciek Sieczka <werchowyna@epf.pl> wrote:
Markus,
I updated yesterday ~ 10 pm, and it failed to build.I'll update again today afternoon and see if now Grass61 builds.
It builds now, cool. Except of:
Errors in:
/home/fishoo/src/straight/grass6/vector/v.drape
/home/fishoo/src/straight/grass6/vector/v.sample
$ cd /home/fishoo/src/straight/grass6/vector/v.drape ; make
gcc -Wl,--export-dynamic
-I/usr/local/include -DPACKAGE=\""grassmods"\"
-o /home/fishoo/src/straight/grass6/dist.i686-pc-linux-gnu/bin/v.drape
OBJ.i686-pc-linux-gnu/main.o -lgrass_vect -lgrass_dig2 -lgrass_dgl
-lgrass_rtree -lgrass_linkm -lgrass_dbmiclient -lgrass_dbmibase
-L/usr/local/lib -lgdal -lgrass_gis -lgrass_datetime -lz -lm -lz
OBJ.i686-pc-linux-gnu/main.o: In function
`main': /home/fishoo/src/straight/grass6/vector/v.drape/main.c:174:
undefined reference to
`G_get_raster_sample' /home/fishoo/src/straight/grass6/vector/v.drape/main.c:205:
`G_get_raster_sample' /home/fishoo/src/straight/grass6/vector/v.drape/main.c:189:
undefined reference to `G_get_raster_sample' collect2: ld returned 1
[/home/fishoo/src/straight/grass6/dist.i686-pc-linux-gnu/bin/v.drape]
Error 1
$ cd /home/fishoo/src/straight/grass6/vector/v.sample ; make
-o /home/fishoo/src/straight/grass6/dist.i686-pc-linux-gnu/bin/v.sample
`main': /home/fishoo/src/straight/grass6/vector/v.sample/main.c:271:
[/home/fishoo/src/straight/grass6/dist.i686-pc-linux-gnu/bin/v.sample]
Error 1
Maciek
Zapraszamy do nas!
Maciek Sieczka <werchowyna@epf.pl> wrote:> Markus,
> I'll update again today afternoon and see if now Grass61 builds.It builds now, cool. Except of:
Errors in:
This is a known problem (Brad forgot to insert sample.c into
lib/gis/). Coming soon, I hope.
