[GRASS5] [bug #4017] (grass) Layers created with v.external have incorrect category index
this bug's URL: http://intevation.de/rt/webrt?serial_num=4017
Subject: Layers created with v.external have incorrect category index
Platform: GNU/Linux/x86
grass obtained from: Other (CDROM etc)
grass binary for platform: Downloaded precompiled Binaries
It is possible to create a vector link using v.external (module says: "Successfully finished"), but when trying to load the new theme into QGIS, I got the error message "The layer is not a valid layer and cannot be added to the map" and - within the command line of GRASS "GRASS_INFO_MESSAGE(26743,12): Using FID column in OGR DB GRASS_INFO_END(26743,12) Invalid layer name, no underscore found: newe added to the map"
Besides, there is no layer in the 'Layer' combobox of the dialog visible.
This issue is also mentioned on the qgis-user list [1].
Radim Blazek wrote in this context:
"Layers created with v.external have incorrect category index (probably in build_ogr.c)".
Wolfgang
[1] http://sourceforge.net/mailarchive/forum.php?thread_id=9495000&forum_id=36786
