[GRASS5] [bug #4021] (grass) error compiling r.le.setup in cvs
The author seems to have lost his interest, so I'll forward to the list.
I have confirmed the bug with today's Grass 6.1 CVS, using GCC 3.4.4, Ubuntu
Breezy.
It shows that building Grass 6.1 with -O3 optimization always leads to errors
in /home/steko/src/grass6/raster/r.le/r.le.setup
This is important because the Grass INSTALL file itself recommends using -O3:
$ cat src/straight/grass6/INSTALL | grep O3
  CFLAGS="-O3 -msse -msse2 -mfpmath=sse -minline-all-stringops" # Intel XEON
64bit processor
  CFLAGS="-O3 -mcpu=<cpu_see_above> -Wall" LDFLAGS="-s" ./configure
Even despite the error at building r.le.setup - does it really make sense for
Grass to be -O3 optimized? As far as I have read it is rather not advised to
use it...
Maciek
Maciek, Stefano,
I have changed the INSTALL file (also for 6.0.2) from
-O3 to -O2.
Thanks for pointing out the problem. I think we can close
the report now.
Breezy.
64bit processor
use it...
Maciek
grass5 mailing list
grass5@grass.itc.it
http://grass.itc.it/mailman/listinfo/grass5
Markus Neteler <neteler itc it> http://mpa.itc.it
ITC-irst - Centro per la Ricerca Scientifica e Tecnologica
MPBA - Predictive Models for Biol. & Environ. Data Analysis
Via Sommarive, 18 - 38050 Povo (Trento), Italy
