this bug's URL: http://intevation.de/rt/webrt?serial_num=4036
Subject: d.vect.thematic: green-blue, custom_gradient, single_color color schemes yield erros
Platform: GNU/Linux/x86
grass obtained from: Trento Italy site
GRASS Version: cvs 2005.01.10
Example below, using colorscheme=green-blue. "expr: argument nieliczbowy" means "expr: the argument is not a number"
d.vect.thematic map=rogow_parcels_01 type=area column=CODE themetype=graduated_colors themecalc=interval layer=1 icon=basic/circle size=5 maxsize=20 nint=4 colorscheme=green-blue pointcolor=255:128:1 linecolor=255:128:1 startcolor=255:128:255 endcolor=255:255:255 monitor=x1
Thematic map legend for column CODE of map rogow_parcels_01
Value range: 1.000000 - 666.000000
Mapped by 4 intervals of 166.25
Color(R:G:B) Value
:: 1 - 167.25
GRASS_INFO_ERROR(29441,1): Unknown color: [::]
0:0:0 167.25 - 333.5
0:0:0 333.5 - 499.75
/usr/local/grass-6.1.cvs/scripts/d.vect.thematic: line 741: let: color1=: syntax error: operand expected (error token is "=")
/usr/local/grass-6.1.cvs/scripts/d.vect.thematic: line 742: let: color2=: syntax error: operand expected (error token is "=")
/usr/local/grass-6.1.cvs/scripts/d.vect.thematic: line 743: let: color3=: syntax error: operand expected (error token is "=")
0:0:0 499.75 - 666.000000
All the other colorschemes, excluding custom_gradient and single_color, work fine...
Maciek
