[GRASS5] [bug #4045] (grass) r.random not so random
this bug's URL: http://intevation.de/rt/webrt?serial_num=4045
Subject: r.random not so random
Platform: WindowsNT/2000/XP
grass obtained from: Other (CDROM etc)
grass binary for platform: Downloaded precompiled Binaries
GRASS Version: 6.0.0
I recently downloaded and installed the cygwin version of GRASS GIS. My primary objective is to generate hillshades. To do so I have been importing shapefiles with contour data and running v.surf.rst. The results have been OK but very segmented. Following the suggestion by Neteler and Mitasova in "Open Source GIS: A GRASS Approach", I attempted to generate random points to merge with the contour points and re-run v.surf.rst. Unfortunately, r.random seems to be generating points clustered at the top of the region. I have been unable to find a way around this in GRASS and have noticed only one or two mentions of the problem in the mailing list archives, but no suggested work-around.
Request: The randomness of r.random requires improvement/correction.
Paul A. Light
That bug has since been fixed.
I'm not sure whether the fix made it into 6.0.1, as there doesn't
appear to be a CVS tag for the 6.0.1 release.
work-around.
Can you try GRASS 6.1? I think it is fixed.
here we go:
http://freegis.org/cgi-bin/viewcvs.cgi/grass6/raster/r.random/creat_rand.c
Revision 2.1 / (as text) / (view) - annotate - [select for diffs] , Tue Jul 5 05:50:31 2005 UTC (6 months, 3 weeks ago) by hamish
Branch: MAIN
Changes since 2.0: +1 -1 lines
Diff to previous 2.0
fix lrand48() for Cygwin & Apple. (fix from Glynn) see:
  http://grass.itc.it/pipermail/grass5/2005-June/018519.html
  http://grass.itc.it/pipermail/grass5/2005-June/018528.html
.. but apparently not backported to 6.0.x.
  (can someone please do if it works?, thanks.)
Hamish
I have sync'ed r.random in 6.0-CVS to the 6.1 version.
The fix will appear in 6.0.2.
