Radim wrote to the grasslist on 2006.02.17:
select c1 from grass_test1 where d1 < 500 / 2 and i1 <> 2 and c1 ~ 'bc'
DBMI-SQLite driver error:
Error in sqlite3_prepare():select c1 from grass_test1 where d1 < 500 / 2 and
near "~": syntax error
EXECUTE: ******** ERROR ********
'~' is not SQL standard, this is not a bug.
So what to do with it? Good to know it is not a bug in sqlite driver, but it
remains a bug in db.test. It may scare naive users and prevent from using
sqlite, too bad. Well, it scarred me. Gosh, I'm naive.
Maciek
I consider it as bug as SQLite supports '~':
http://www.sqlite.org/lang_expr.html
"Supported unary operators are these:
Question is if it is probably not passed correctly to sqlite?
Note the use of the word "unary". In the above select statement, the ~
is being used as a /binary/ operator, which SQLite doesn't support:
SQLite understands the following binary operators, in order from
highest to lowest precedence:
= == != <> IN
AND
OR
= == != <> IN
AND
OR
Ah, I see - but what does it mean for db.test?
Add a sqlite test to skip it?
> = == != <> IN
> AND
> OR
As it's an extension (rather than standard SQL), the test should be
disabled by default and only run (if at all) for specific back-ends
which are known to support it.
