[GRASS5] [bug #4064] (grass) r.in.srtm: doesn't work, though it's a latlong WGS84 projection
Markus,
(CCing Frank)
I have built GDAL from CVS today to sort out the
https://intevation.de/rt/webrt?serial_num=4070 bug.
As a side effect, I don't need the to override projection check for r.in.gdal
inside r.in.srtm to make it work anymore. See how the projections "appear to
match" back now:
$ r.in.srtm input=/home/john/gis/dane/srtm2/N51E016 output=N51E016_v2_newgdal
Extracting /home/john/gis/dane/srtm2/N51E016...
Archive: /home/john/gis/dane/srtm2/N51E016.hgt.zip
  inflating: N51E016.hgt
Converting input file to BIL...
Projection of input dataset and current location appear to match.
Proceeding with import...
100%
CREATING SUPPORT FILES FOR N51E016_v2_newgdal
r.in.gdal complete.
Color table for [N51E016_v2_newgdal] set to srtm
Done: generated map N51E016_v2_newgdal
(Note: Holes in the data can be closed with 'r.fillnulls' using splines)
I haven't changed anything in my Location setup since the bug report neither
altered Grass61 instalation. All I did was to replace my 2006-01-09 CVS GDAL
build with a fresh one.
Magic?
How is your v.in.ogr problem now Markus?
Maciek
