this bug's URL: http://intevation.de/rt/webrt?serial_num=4089
Subject: r.out.gdal doesn't handle multiple creation options correctly
Platform: Mac OSX
grass obtained from: Trento Italy site
GRASS Version: 6.0.1/6.1 CVS
GDAL version: 1.3.1
The documentation for r.out.gdal states that multiple creation option can be specified (though it
doesn't say how - separate by spaces and quote the whole thing). But it doesn't pass that to gdal
correctly. In gdal_translate, multiple creation options are specified separately, as in:
-co OPT1=VAL -co OPT2=VAL ...
But r.out.gdal just prepends a single -co to the whole string passed to r.out.gdal (and quotes are lost
also):
-co OPT1=VAL OPT2=VAL
So, any extra creation options are seen as gdal_translate options, not creation options.
As a workaround, I found it is possible to added the extra needed '-co' tags to r.out.gdal and all
creation options are then recognized:
r.out.gdal .... createopt="OPT1=VAL -co OPT2=VAL"
which comes out in the gdal_translate command as:
... -co OPT1=VAL -co OPT2=VAL
as desired.
I suspect the metadata r.out.gdal option has the same problem.
To fix r.out.gdal, it would have to loop thru each of the items in the createopt string and prepend -
co to each.
