this bug's URL: http://intevation.de/rt/webrt?serial_num=4110
Subject: v.digit: Could not set Tcl system encoding to
Platform: GNU/Linux/x86
grass obtained from: CVS
GRASS Version: 2006-02-20
When editing attributes in v.digit plenty of "Could not set Tcl system encoding to" are printed to stdout (3 per 1 edit action). An error? Warning? Why doesn't it say what encoding it couldn't set to, actually?
v.digit map=huba -n
D0/0: Name = cat
D0/0: Name = buba
D0/0: Name = _grass_internal_database_encoding
I have my GRASS_DB_ENCODING set:
GRASS 6.1.cvs (caves_utm33):~ > echo $GRASS_DB_ENCODING
utf-8
Maciek
P.S.
The new "Edit line/boundary" tool is excellent! Thanks to Ralf Gerlich and Markus Neteler!
Maciek
actually?
v.digit map=huba -n
D0/0: Name = cat
D0/0: Name = buba
The two points in the code (lib/form/form.c) which generate this error
read:
if ( Tcl_SetSystemEncoding(interp, Cols[i].value) == TCL_ERROR ) {
fprintf(stderr,
"Could not set Tcl system encoding to %s\n", Cols[i].value);
and:
if ( Tcl_SetSystemEncoding(interp, encoding_val) == TCL_ERROR ) {
fprintf(stderr,
"Could not set Tcl system encoding to %s\n", encoding_val);
IOW, the encoding name is an empty string.
