this bug's URL: http://intevation.de/rt/webrt?serial_num=4111
Subject: d.m crashes
Platform: Mac OSX
GRASS Version: 6.1.cvs checked out 02222006
Kirk Wythers. I noticed that d.m crashes now upon startup. The error message is:
GRASS 6.1.cvs (minnesota_utm):~ > d.m
GRASS 6.1.cvs (minnesota_utm):~ > Error in startup script: child process exited abnormally
while executing
"close $input"
(procedure "Dm::create" line 38)
invoked from within
"Dm::create"
(procedure "main" line 33)
invoked from within
"main $argc $argv"
(file "/usr/local/grass-6.1.cvs/etc/dm/d.m.tcl" line 1629)
Platform: Mac OSX
while executing
"close $input"
invoked from within
"Dm::create"
invoked from within
"main $argc $argv"
The "close $input" should be within the catch, as $input won't be
valid if the open command fails.
While glancing at the code, I also noticed the following in both
Dm::displmon and Dm::monitor:
return
close $input
The close needs to come before the return.
I've done this now. So hopefully it is finally solved. Thanks for the
advice.
Michael
______________________________
Arizona State University
Tempe, AZ 85287-2402
USA
voice: 480-965-6262; fax: 480-965-7671
Date: Wed, 22 Feb 2006 17:54:39 +0000
To: Request Tracker <grass-bugs@intevation.de>
Cc: <grass5@grass.itc.it>, Michael Barton <michael.barton@asu.edu>
Subject: Re: [GRASS5] [bug #4111] (grass) d.m crashes
Platform: Mac OSX
is:
exited abnormally
while executing
"close $input"
invoked from within
"Dm::create"
invoked from within
"main $argc $argv"
return
close $input
