[GRASS5] [bug #4118] (grass) can not use d.erase -f
this bug's URL: http://intevation.de/rt/webrt?serial_num=4118
Subject: can not use d.erase -f
Platform: WindowsNT/2000/XP
grass binary for platform: Downloaded precompiled Binaries
GRASS Version: GRASS 6.0.0 (2005)
I can not use "d.erase -f" to remove the frames when clearing the display, after using "d.rast.leg" as what's said on the Reference Manual.
Here is screen info:
GRASS 6.0.0 (spearfish):~ > d.erase -f
Sorry, <f> is not a valid flag
Description:
Usage:
Parameters:
Manual.
The -f flag isn't present in 6.0.0. It was added on 2005/06/21, so you
will need a version which was released after that date.
[BTW, neither 6.0.1 nor 6.0.2 appear to have CVS tags, so it's
impossible to determine which version of a file was used for those
releases.]
I think that is d.erase -e
Michael
Arizona State University
Tempe, AZ 85287-2402
phone: 480-965-6213
fax: 480-965-7671
Reply-To: Request Tracker <grass-bugs@intevation.de>
Date: Sun, 26 Feb 2006 05:13:36 +0100 (CET)
To: <grass5@grass.itc.it>
Subject: [GRASS5] [bug #4118] (grass) can not use d.erase -f
Description:
Usage:
Parameters:
> Manual.
releases.]
Good point. I'll tag 6.0.2 now and update the release procedure.
> > Manual.
> releases.]
If you've done "cvs update" since the release, "cvs tag" will apply
the tag to the updated versions, not the versions in the release. In
that case, you can use "cvs rtag -D <date> ..." with the correct date
(the time of the "cvs update" command corresponding to the released
versions) instead.
BTW, I would suggest leaving the CVS directories in the tarballs, so
that someone can use "cvs update" to get a later version. Ideally, the
CVS/Root files should be set for anonymous (pserver) access, but it's
easy enough to replace them using a script if you have a copy which
was checked out using ssh.
No, it's "d.erase -f" or "d.frame -e" to remove all frames and erase
the screen (using Dclearscreen(), which erases the screen to the
background colour, not the current colour or the colour specified by
the color= option for d.erase; this can be used to erase a PNG monitor
to transparent).
> > > Manual.
> > releases.]
No, I didn't. I have a separate directory for that.
versions) instead.
The only file changed back (and forth) is include/VERSION to get the
6.0.2 number into the tag. The other files are untouched.
I darkly remember that it was discouraged to leave the CVS directories
in the release tarballs (it was like that some years ago if I recall
correctly).
The snapshots however contain the CVS directories.
to transparent).
fix applied to the releasebranch_6_0 branch in CVS.
this bug can be closed
Hamish
