[GRASS5] [bug #4123] (grass) v.in.ogr PROJ recognition bug
this bug's URL: http://intevation.de/rt/webrt?serial_num=4123
Subject: v.in.ogr PROJ recognition bug
I tried to import the sample soils map from
PostGIS (1.1.x, on PG 8.0.x):
ogrinfo "PG:host=localhost dbname=postgis" soils | head -25
INFO: Open of `PG:host=localhost dbname=postgis'
using driver `PostgreSQL' successful.
Layer name: soils
Geometry: Polygon
Feature Count: 737
Extent: (589443.750000, 4913923.000000) - (609546.187500,
4928106.000000) Layer SRS WKT:
PROJCS["UTM Zone 13, Northern Hemisphere",
    GEOGCS["clark66",
        DATUM["North_American_Datum_1927",
            SPHEROID["clark66",6378206.4,294.9786982]],
        PRIMEM["Greenwich",0],
        UNIT["degree",0.0174532925199433]],
    PROJECTION["Transverse_Mercator"],
    PARAMETER["latitude_of_origin",0],
    PARAMETER["central_meridian",-105],
    PARAMETER["scale_factor",0.9996],
    PARAMETER["false_easting",500000],
    PARAMETER["false_northing",0],
    UNIT["meter",1]]
FID Column = ogc_fid
Geometry Column = wkb_geometry
cat: Integer (0.0)
label: String (0.0)
But GRASS tells me:
v.in.ogr dsn="PG:host=localhost dbname=postgis" layer=soils
output=soils_pg type=boundary,centroid ERROR: Projection of dataset
does not appear to match current location.
       LOCATION PROJ_INFO is:
       datum: nad27
       nadgrids: conus
       proj: utm
       ellps: clark66
       a: 6378206.4000000004
       es: 0.0067686580
       f: 294.9786982000
       zone: 13
       cellhd.proj = 0 (unreferenced/unknown)
       You can use the -o flag to v.in.ogr to override this check.
       Consider to generate a new location with 'location' parameter
from input data set.
It seems that there are still definition issues with PROJ.
any ideas?
I have found the opposite behaviour. I can import any dataset with
different proj-information inside the spearfish60-location...
Something is messed up there.
Could anybody have a look into this?
Best
  Stephan
