On Thu, 23 Mar 2006 08:43:36 +0100
"Radim Blazek" <radim.blazek@gmail.com> wrote:
On 3/22/06, Maciek Sieczka <werchowyna@epf.pl> wrote:
> Now, not using "debug=clean": the v.buffer creates _mostly_ good
> result when compared to r.buffer at resolution =1. But there are at
> least 2 places with errors visible in v.buffer behaviour. Please
> see the attached screendump, you will spot them easily.
> The YELLOW lines are the v.buffer and r.buffer input.
> The RED backgroung is r.buffer output (GOOD).
> The BLACK lines are v.buffer output, with at least 2 ERRORS visible,
> indicated by GREEN circles.
> Are those possible to be fixed Radim?
Not now by me. If possible publish your input data so that it can
be used for debugging in future.
Here (3,3 MB):
http://www.biol.uni.wroc.pl/sieczka/udostepnione/grass/huha2.tar.bz2
There is an input vector boundaries
x_extr
and the 100m buffer with a visible fault
x_extr_buff100
I deleted my original input and created it once more to prepare this
sample dataset - and somehow now there is only 1 error in the
v.buffer output instead of 2 as previously... Hmm. Maybe my fault.
How do look those 2 places if run with debug=clean?
Topologicaly clean, but the fault in buffer is still clearly visible.
Maciek
