this bug's URL: http://intevation.de/rt/webrt?serial_num=4178
Subject: r.stats segfault
Platform: GNU/Linux/x86
GRASS Version: grass-6.1.cvs_src_snapshot_2006_01_21
Running the following segfaults, r.stats should exit gracefully with an invalid map list:
r.stats -a input=
r.stats: Segmentation fault
Should be simple to fix
Cheers,Joel
H_B
2
> r.stats -a input=
Done. More interesting is that this one works:
G> r.series in= out=foo meth=average
100%
(full of nan, but I use gcc -g..)
Maybe a general fix in lib/gis/parser.c is needed for ->answers?
Hamish
H_B
3
> r.stats -a input=
These modules should be checked & fixed if needed before closing this bug:
r.buffer
r.cats
r.circle
r.compress
r.contour
r.cost
r.covar
r.cross
r.distance
r.drain
r.fill.dir
r.le
r.los
r.null
r.out.mpeg
r.out.vtk
r.profile
r.quant
r.random.surface
r.report
r.rescale
r.rescale.eq
r.to.rast3
r.transect
r.walk
r.water.outlet
r.what
wildfire/
base/
r3.mkdspf
r3.out.vtk
r3.to.rast
v.build
v.category
v.clean
v.distance
v.extract
v.extrude
v.in.dwg
v.in.ogr
v.label
v.mkgrid
v.net.iso
v.normal
v.overlay
v.patch
v.to.db
v.type
v.what
d.ask
d.barscale
d.geodesic
d.grid
d.legend
d.linegraph
d.nviz
d.rast
d.rhumbline
d.save
d.text
d.text.freetype
d.vect
d.vect.chart
d.what.rast
d.what.vect
d.zoom
g.mapsets
g.pnmcomp
g.region
manage/
if(! option->answer)
G_fatal_error(..);
doesn't get triggered,
if(option->answers[0] == NULL )
G_fatal_error(..);
does.
Hamish
