For an update: with today's CVS from a while ago this issue still applies.
Displaying vectors is impossible. Once I try displaying vector, gis.m Output
window goes crazy, gis.m freezes. After closing the gis.m window by force (not
always possible, sometimes have to use kill -9) there is a following output in
the terminal, if it is telling you anything:
PNG: GRASS_TRUECOLOR status: TRUE
PNG: collecting to file:
//home/grassdata/wro_gps_ll/PERMANENT/.tmp/quercus/11232.0.ppm,
GRASS_WIDTH=642, GRASS_HEIGHT=428
Graphics driver [gism] started
invalid command name ".gronsole.gronsole"
while executing
"$gronsole annotate $cmd [list gism running]"
(procedure "runcmd" line 4)
invoked from within
"runcmd "g.mremove -f region=mon_$mon ""
(procedure "MapCanvas::cleanup" line 6)
invoked from within
"MapCanvas::cleanup $mon $destroywin"
(command bound to event)
while executing
invoked from within
"runcmd "g.mremove -f region=mon_*""
(procedure "Gm::cleanup" line 29)
invoked from within
"Gm::cleanup $destroywin"
can't read "_widget(.#BWidgetClass#SelectColor,var)": no such element in array
while executing
"string length $_widget($path,var)"
(procedure "SelectColor::_destroy" line 4)
invoked from within
"SelectColor::_destroy .#BWidgetClass#SelectColor"
wrong # args: should be "Gm::cleanup destroywin"
while executing
"Gm::cleanup "
invoked from within
"if { "." == "."} { Gm::cleanup }"
Please note, that if I use "Zoom to current region" prior to displaying the
vector, it displays fine. But if I try to display my vector right after it's
added, there is a freeze as described.
Is anybody else having this bug?
Maciek
