[GRASS5] [bug #4246] (grass) NVIZ: segfault in kanimation panel
re. segfault in nviz if you use a d.nviz generated script:
G61> nviz script=somefile.nvsrc
The segfaults happens when it tries to add a keyframe:
visualization/nviz/src/anim_support.c
line ~410 in Nadd_key_cmd()
   G_free (listels);
if I comment that line out, the script runs, nviz loads, and all is good.
printf(%p) shows listels at 0xbfffee6c
I notice in the compiler warnings:
anim_support.c:367: warning: passing arg 4 of `Tcl_SplitList' from
incompatible pointer type
which is this:
    if (Tcl_SplitList(interp, argv[2], &numels, &listels) != TCL_OK)
is that call promoting listels to something else?
Is there a better way of debugging nviz than just peppering puts and printf's?
gdb is useless for it.
thanks,
Hamish
Hamish,
I took a quick look at this and I cannot duplicate the error. I do get
the compiler warning for all of the Tcl_SplitList in src. According to
TCL recent documentation arg 4 in Tcl_SplitList should actually be
"const char **". If I change
char **listels;
in anim_support.c (line ~933)
to const char **listels;
I do not get the compiler warning.
Also, according to the Tcl_SplitList documentation, the **listels
argument should be freed. They recommend using
Tcl_Free((char *) argv);
I am not sure why the free call would be creating a problem.
Hope this helps.
Bob
   G_free (listels);
which is this:
thanks,
Hamish
grass5 mailing list
grass5@grass.itc.it
http://grass.itc.it/mailman/listinfo/grass5
I am using Debian with TclTk 8.4, which is a new thing. See:
  http://article.gmane.org/gmane.comp.gis.grass.devel/11177
  http://grass.itc.it/pipermail/grass-commit/2006-March/021104.html
Maybe a similar issue?
(I haven't recompiled with tcltk 8.3 yet to check if this is the case,
obviously it would be a good idea to do so. It works fine with a CVS
version from February (compiled with tcltk 8.3), so I would guess this
is a pretty strong lead)
I do get the compiler warning for all of the Tcl_SplitList in src.
According to TCL recent documentation arg 4 in Tcl_SplitList should
actually be "const char **". If I change
char **listels;
If I add "const", the warning goes away for me too. But it still
segfaults on Load anim file.
I also notice these warnings:
<command line>:5:1: warning: "__STDC__" redefined
In file included from anim_support.c:11:
interface.h:363: warning: `struct Map_info' declared inside parameter list
interface.h:363: warning: its scope is only this definition or declaration, which is probably not what you want
and eight "warning: passing arg 1 of `...' as `float' rather than `double' due to prototype"
see above links ??
I've made a number of small cleanups to the kanim code in the last week
to make things a little easier on the user (also d.nviz, nviz2.2_script).
Hopefully it will just be smoother and the changes won't be noticed.
The Keyframe Animator help page is extended including an example and
should be easier to follow.
Also I added an #ifdef to the MPEG code to make it easy to switch to
using the XVID codec. (compile with gcc -D"USE_XVID") This should really
be an enviro var or GIS var setting, but for now it's a quick proof of
concept hack.
Result of this is that making movies is somewhat easier now. Great
synergy with r.in.wms(x2) or r.in.onearth scripts to fetch SRTM and
LANDSAT. Process LANDSAT image with Markus's i.landsat.rgb & even
better.
Q: If I make a track with d.nviz the camera looks straight down, not
forwards along the track. Is this normal/expected?
cheers,
Hamish
> char **listels;
I also get these warnings?
see above links ??
Taking a look at some of the other Tcl_SplitList calls (for example in
draw.c) the char is freed with G_free ((char *) ...). I would expect
these to also segfault if it was a problem with G-free. Try simply
changing
G_free (listels);
to
G_free ((char *) listels);
These all sound great. The extended help is a good idea as the Keyframe
Animator can be quite difficult to learn.
concept hack.
Instead of a compile flag could we try something like ...
codec = avcodec_find_encoder(CODEC_ID_XVID);
if (!codec)
  codec = avcodec_find_encoder(CODEC_ID_MPEG1VIDEO);
  if (!codec) {
    fprintf(stderr, "codec not found\n");
    return(-1);
This way it tries to load the better quality codec, and if it fails it
will load the old standard mpeg1. I have not tested it to see if it
works.
better.
If the camera is looking down then you need to increase the dist
parameter. The combination of the ht and dist parameters are what
determine the camera look angle.
cheers,
Hamish
Hope this helps.
Bob
> > should actually be "const char **". If I change
> > char **listels;
> parameter list interface.h:363: warning: its scope is only this
> see above links ??
changing
G_free (listels);
to
Nope, still segfaults.
> really be an enviro var or GIS var setting, but for now it's a quick
> proof of concept hack.
if (!codec)
  if (!codec) {
    return(-1);
works.
Maybe someone wants something more than XVID or MPEG-1?
(shrug- anybody?)
XVID requires the canvas to be some multiple of 16x16, and fails to
load (without telling why) or produces artifacts in the output if not.
So as a default it may be tricky for newcomers.. But most/all other
encoders have the same problem. (including MPEG-1??)
Oh, ok. I was keeping dist= small as I was getting out-of-region
messages and skipped points if I went within that distance to the edge
of the region. Any thoughts on extending the module to work with a
vector line? Maybe needs a cat= option tp pick specific line and a -r
reverse flag to follow it the other direction. I'm thinking flying above
a road or weaking the flight path in v.digit.
Hamish
