[GRASS5] [bug #4249] (grass) v.build.polylines or v.clean: polylines created by v.build.polylines are broken back into separate lines by v.clean
this bug's URL: http://intevation.de/rt/webrt?serial_num=4249
Subject: v.build.polylines or v.clean: polylines created by v.build.polylines are broken back into separate lines by v.clean
Platform: GNU/Linux/x86
grass obtained from: CVS
GRASS Version: 2006-04-05
### There is a vector consisted of 3 lines connected with nodes:
$ v.build fafkulec
Building topology ...
3 primitives registered
Building areas: 100%
0 areas built
0 isles built
Attaching islands:
Attaching centroids: 100%
Topology was built.
Number of nodes : 3
Number of primitives: 3
Number of points : 0
Number of lines : 3
Number of boundaries: 0
Number of centroids : 0
Number of areas : 0
Number of isles : 0
### I need to join lines into one:
v.build.polylines input=fafkulec output=fafkulec_poly
The number of lines in the binary map is 3
Polyline 0: start line = 3
The number of polylines in the output map is 1
1 primitives registered
0 areas built
0 isles built
Attaching islands:
Topology was built.
Number of nodes : 1
Number of primitives: 1
Number of lines : 1
Number of areas : 0
Number of isles : 0
### Fine. Only one line. But once I run v.clean on it, lines become separated back. Somehow, points at which v.build.polylines joined the lines are taken for errors by the v.clean:
$ v.clean input=fafkulec_poly output=fafkulec_poly_cl type=line error=fafkulec_poly_er tool=break,rmdupl
| Tool | Threshold |
| Break | 0.000000e+00 |
| Remove duplicates | 0.000000e+00 |
Copying vector lines ...
Rebuilding parts of topology ...
Topology was built.
Number of nodes : 1
Number of lines : 1
Number of areas : -
Number of isles : -
Tool: Break lines at intersections
Intersections: 2
Tool: Remove duplicates
Duplicates: 0
Rebuilding topology for output vector ...
0 areas built
0 isles built
Attaching islands:
Topology was built.
Number of nodes : 3
Number of lines : 3
Number of areas : 0
Number of isles : 0
Building topology for error vector ...
2 primitives registered
0 areas built
0 isles built
Attaching islands:
Topology was built.
Number of nodes : 2
Number of primitives: 2
Number of points : 2
Number of lines : 0
Number of areas : 0
Number of isles : 0
All the vectors mentioned above are in the location for download here:
http://www.biol.uni.wroc.pl/sieczka/udostepnione/grass/poly_clean.tar.bz2
Maciek
