This functionaltiy would have been really good to know about! I have been
scripting around the overwrite problem without knowing that the --o flag
existed:
eval `g.findfile mapset=PERMANENT element=cell file=$MAP`
if [ -n "$file" ] ; then
echo "Error: file already exists, removing... "
g.remove rast=$MAP
else
Oh well, I get to trim out a lot of useless code from my scripts now
~ Eric.
-----Original Message-----
To: wegmann@biozentrum.uni-wuerzburg.de; grass5@grass.itc.it
Sent: 4/25/2006 1:06 PM
Subject: Re: [GRASS5] [bug #4331] (grass) delete if file exist - flag
Martin,
I don't know why --o instead of -o.
I just say discussion of it on the list some time back and filed it away
until I needed it.
It should be documented if it is not.
Michael
Center for Social Dynamics and Complexity
Arizona State University
phone: 480-965-6213
fax: 480-965-7671
From: Martin Wegmann <wegmann@biozentrum.uni-wuerzburg.de>
Reply-To: <wegmann@biozentrum.uni-wuerzburg.de>
Date: Tue, 25 Apr 2006 18:14:48 +0200
To: <grass5@grass.itc.it>
Hello Michael,
to which command do you refer? I looked into the man pages and found
no -o
flag there and tried it inside GRASS with
r.resample/r.rescale/r.rescale but
received everytime the "-o is not a valid flag".
stop wait; I tried it with --o (two dashes) and it works.
Why two dashes and not one as every other flag?
thanks for pointing me to it.
Shall I (or somebody else) add "--o" to all r.* html pages?
regards, Martin
On Tuesday 25 April 2006 17:43, Michael Barton wrote:
You're in luck. This DOES exist.
Just add --o to the end of a command and it will force an overwrite
of any
existing file.
Michael
phone: 480-965-6213
fax: 480-965-7671
Reply-To: Request Tracker <grass-bugs@intevation.de>
Date: Mon, 24 Apr 2006 18:37:29 +0200 (CEST)
Subject: [GRASS5] [bug #4331] (grass) delete if file exist - flag
this bug's URL: http://intevation.de/rt/webrt?serial_num=4331
Subject: delete if file exist - flag
Platform: GNU/Linux/x86
grass obtained from: Trento Italy site
GRASS Version: cvs 24.04.2006
Hello,
a flag for each module to delete a raster/vector if the file already
exists would be good.
A hidden g.remove with the respective name would do the job. That
would
make it easier for users to play with certain settings and not
substituting each time the old name or run g.remove.
BTW the delete file handling is not consistent (but I think that has
been
discussed earlier) r.mapcalc is just overwriting the file but e.g.
r.rescale does prompt an error message that the file exist.
regards, Martin
-------------------------------------------- Managed by Request
Tracker
grass5 mailing list
grass5@grass.itc.it
http://grass.itc.it/mailman/listinfo/grass5
Martin Wegmann
DLR - German Aerospace Center
German Remote Sensing Data Center
Dept.of Geography
Remote Sensing and Biodiversity Unit
Dept. of Animal Ecology and Tropical Biology
University of Wuerzburg
Am Hubland
97074 Würzburg
phone: +49-(0)931 - 888 4797
mobile: +49-(0)175 2091725
fax: +49-(0)931 - 888 4961
http://www.biota-africa.org
http://www.biogis.de
grass5 mailing list
grass5@grass.itc.it
