this bug's URL: http://intevation.de/rt/webrt?serial_num=4366
Subject: core dump in r.to.vect
Platform: GNU/Linux/x86
grass obtained from: CVS
GRASS Version: GRASS 6.1.cvs checkout 4/27/06
There is a core dump in r.to.vect when run over DCELL rasters. Segfault originates at this line:
#0 extract_areas () at areas.c:283
283 v_list[col]->node = h_ptr->node = 1;
I think that in r.to.vect there should be an error message on trying to run it on a raster other than of CELL type.
H_B
2
confirmed,
#spearfish
r.mapcalc tmp_fields='double(fields)'
r.to.vect in=tmp_fields out=tmp_fields fea=area
gdb shows the segfault in the same place for this example as above.
while it segfaults if either v_list[col]->node = 1; or h_ptr->node = 1;
is run first on its own,
printf("v_list =[%p] h_ptr=[%p]\n", v_list, h_ptr);
shows
v_list =[0x806bae8] h_ptr=[(nil)]
, but in the CELL case h_ptr has value.
Hamish
