[GRASS5] [bug #48] (grass) /etc/monitorcap: paths hardcoded
While skimming though the code, i noticed that R_parse_monitorcap appends
$GISBASE if the path does not start with a '/' (i. e. is relative). I can't
remember if this is new or if it was always this way. Perhaps someone else can
comment.
I just removed the hardcoded path and d.mon works. I'll do some more testing.
Please tell me if i should remove all the references and change the Gmakefiles
and setup skripts.
Are there any other places where the paths are hard-coded?
What about etc/digcap?
Andreas
comment.
"cvs log" says that src/libes/raster/parse_mon.c hasn't changed since
it was initially added to CVS on 1999-12-29.
