this bug's URL: http://intevation.de/rt/webrt?serial_num=802
Subject: r.in.gdal: number of imported rows incorrect?
grass downloaded at: CVS Server, Germany
grass sources source: yes, I am using the latest GRASS from CVS
it seems that r.in.gdal uses an unusual row index
(src/raster/r.in.gdal/main.c):
for (row = 1; row <= nrows; row++)
Usually the row number starts with 0.
Any ideas?
Thanks
This isn't limited to r.in.gdal; there is other code in GRASS which
uses the Pascal convention for array indices (e.g. i.cca).
In the case of the above file, this means that the call to G_percent()
is wrong; the other references to "row" are as "row-1".
r.in.gdal is trivial to fix, as the issue is limited to this loop. I
didn't touch i.cca, as the one-based convention is used throughout.
As Frank pointed out (a while back), this is actually correct; it
ensures that:
a) the reported percentages are correct (G_percent() is called at the
end of each pass), and
b) the final call to G_percent() reports 100% and prints a newline.
