[GRASS5] [bug #823] (grass) rast problems dealing with null maps on DEC Alpha (Linux)
this bug's URL: http://intevation.de/rt/webrt?serial_num=823
Subject: rast problems dealing with null maps on DEC Alpha (Linux)
Platform: Linux/Alpha64
Linux distro: Debian
linux cpu: Alpha
Xwindows version: XFree 4.1.0
Xwindows manager: KDE 2.x
TclTk version: tcl/tk 8.3
grass downloaded at: Baylor site
grass binary for platform: I compiled the sources myself
grass sources source: no, I got a source code package from the server,
5.0.0pre2
c compiler name: gcc
Anything to do with floating point raster maps with null map on a DEC Alpha
causes a
floating point exception... FIX taken from source of Grass 4.2.1 with FP +
NULL patches is to not use NaN to mark nulls in floating point maps but
rather to use FLT_MAX...
I could probably make a patch available if required... but if is #if 0
marked on code I am using here...
causes a
That isn't a fix, but a workaround.
Do you have any idea what causes the FP exception? Or is it any
attempt to perform FP operations on NaN values?
linux cpu: Alpha
5.0.0pre2
causes a
Can you try compiling with the "-mieee" switch, e.g.
  CFLAGS=-mieee ./configure ...
The "gcc" Info file suggests that the Alpha's floating-point support
takes some shortcuts, which result in NaN and infinity not working:
`-mieee'
     The Alpha architecture implements floating-point hardware
     optimized for maximum performance. It is mostly compliant with
     the IEEE floating point standard. However, for full compliance,
     software assistance is required. This option generates code fully
     IEEE compliant code _except_ that the INEXACT FLAG is not
     maintained (see below). If this option is turned on, the CPP
     macro `_IEEE_FP' is defined during compilation. The option is a
     shorthand for: `-D_IEEE_FP -mfp-trap-mode=su -mtrap-precision=i
     -mieee-conformant'. The resulting code is less efficient but is
     able to correctly support denormalized numbers and exceptional
     IEEE values such as not-a-number and plus/minus infinity. Other
     Alpha compilers call this option `-ieee_with_no_inexact'.
