[GRASS5] [bug #831] (grass) Can't start any display
this bug's URL: http://intevation.de/rt/webrt?serial_num=831
Subject: Can't start any display
Platform: Linux/Intel
Linux distro: SuSe
linux cpu: AMD (K6, ...)
Xwindows version: Xfree 4.0.x
Xwindows manager: KDE 2.x
TclTk version: tcl/tk 8.3
grass downloaded at: CVS Server, Germany
grass binary for platform: I compiled the sources myself
grass sources source: yes, I am using the latest GRASS from CVS
c compiler name: gcc
Can't start any displays. d.mon gives the following errors:
x0
Usage: x0 [-] "input_fifo output_fifo" [nlev]
Please start graphics monitor <x0>.
Error - Graphics monitor <x0> not running!
Problem selecting x0. Will try once more
> x0
XDRIVER was built for FIFOs while mon.start was built for sockets.
There are two main possibilities:
1. Old object files weren't cleaned out with "make distclean" before
re-compiling.
2. src/display/devices/lib/main.c included the wrong config.h file.
To determine whether case 2 applies, check the order of the -I
switches in the compilation command which was used for that file. If
you didn't save the output from the build process, you'll need to
re-do it.
